BBE Acoustimax help
thousandyards
Member
Brisbane
Hi everyone....relative newbie here. I was using my BBE Acoustimax for a few years before it stopped passing signal a few years ago. Bought it brand new, it was pretty well looked after. So I popped it open to have a squiz inside and see if there was anything obviously amiss.
There's a bit of oxidation on the solder side of both PCBs - other sides are pristine. The worst of it is on the smaller PCB - 2824 and 2827 in the images.
Would anyone be able to give any advice as to how bad this actually is? I have no frame of reference for it, so it could be unserviceable, just a bit of surface stuff, or anything in between. It's a great little DI/Preamp/EQ that I would love to get back into use!
**EDIT** I gave some of the surface a clean with Servisol Clean and Lube - not sure if this is a good idea, rank stupidity, or somewhere in between!
Thanks all!
More just wondering about the condition of the board and whether it's still ok.
I don't see anything wrong with these PCB's. There is no oxidation, it's just the flux residues.
You may want to clean them with isopropylic alcool, but I don't think it would change anything to the situation.
There is a faulty part somewhere.
Your first endeavour is finding a schematic.
Ther is one here BBE - Acoustimax but I can't vouch for it.
66D4BC6C-438A-48A0-9F14-D701691E0C29.jpegeven this wouldn’t be a problem?
