I am building a Phaedrus SPIRIT phantom-powered U47-style mic with this transformer.Btw. BV08 primaries and secondaries are usually connected in series on both sides (not with each other) or secodaries in parallel in some cases but isn't it possible also to connect the primaries in parallel? That would make the transformer into about 3:1 one, is that ok, what would happen to the primary inductance (number of turns remains the same)?
Measuring the winding resistances should at least give a clue?
I made an U47 with this transformer. Grey and Yellow are connected together. I used Moby's diagram as a reference. Here's a pic of my build. And check Moby's page...Anyone know the wiring diagram for BeesNeez BV-08L ?
Thanks, I was also using Moby's Bv-08 as reference, since I used it with my D-EF47.I used Moby's diagram as a reference.
Don't expect to get any answer from Beesneez. I wrote them few times without any answer.Thanks, I was also using Moby's Bv-08 as reference, since I used it with my D-EF47.
It seems like such an obvious thing to have schematics. I am building it like the AMI U47, with the resistors on two little boards surrounding the transformer, so I want the wiring correct the first time.
Primary + | red |
Primary - | black |
Secondary + | pink |
Secondary - | blue |
Primary spools | yellows tied together |
Secondary spools | whites tied together and center tapped |
U47what mics a 6.5:1 is even used in, anyway).
