tony666
After searching the META forum and Electronics in Meccano site I still have a question about the Transformer I bought. It has the following pins/description :
0 - 115V 0 - 115V
0 - 15V 0 - 15V
I'm giving it 230 V AC in and need +- 15V out. Is it correct when I connect the 115V pin in the center with the 0 V in the center and connect the outside pins 0 and 115V to the 230V AC signal?
For the output, connect center 0 and center 15V pin and use these as 0V for the power supply?
How do I mount the Block transformer on the 19" chassis? It doesn't fit on a universal PCB board?
0 - 115V 0 - 115V
0 - 15V 0 - 15V
