The tube sections are common to all Behringers T19xx range , its through hole so there is a chance you can re-jig it . The tubes run on something like 25volts on the plate and I think the heaters are way undervolted too. The solid state sections are smd and broadly similar to other processors in the Behringer range . I had considdered modding one before , the one with 8 channels of tube processing called the T1950 Magician, those units are long since out of production at this stage but can be found cheaply enough if your lucky . Theres one mic pre with tube , one limiter/comp , the one you have with the psycho acoustic processing and the T1950 in the range.
If you wanted to make the tubes in them run at proper voltages a new power supply would be required , Im not sure its even worth the trouble to be honest.
