Best Fet input dual opamp?
SASMastering
Member
London UK
Hi there, just wondering what a decent replacement op-amp for a TL082 FET input would be?
Thanks any options to investigate - I see OP2134's as a possibility.
OPA2134 doesn't have FET inputs. Perhaps you're thinking of the OPA2132?
-a
Do you have the option for SMD? There are some very good modern fet input options that are SMD only (SOIC-8). For example LME49880, AD8599 and AD8512. TLE2072 is another modern option - quite cheap - also available as PDIP.
The OPA2134 is the 'audio' version of the OPA2132. The latter still seems to perform a little better for audio as well IMO.
But it really depends on the application. In EQ circuits designed with the TL072 in mind I actually liked OPA2132 best. In the signal path not so much.
