I’m trying to work out the best way to supply heater voltage to eight JJ E88CC or EH 6922 via PCB. AC is right out. Regulation is unnecessary (and wasteful). There are totem poles in the circuit, and while I don’t necessarily have to elevate the heater supply, I hear it’s good practice with an eye towards cathode lifespan. Doing it bipolar seems to make more sense than stacking the heater voltage atop a reference voltage. Luckily, two diode drops and two Vbe drops get me from rectified potential back down to filament spec. My lack of a center tap does complicate things.
R and C values are generic for scale. That’s millifarads, not micro.
Do I need loads from my new rails to the reference voltage? At the 7.5V mark, the 6.3V mark, or from the bases? Could I nix the center reference entirely after the rectifier and just cap across the rails? Any suggestions for the right NPN / PNP pair in through hole? Are there significant advantages in moving to a Sziklai approach in this application?
