I've realised I don't fully understand PCB return current. Lets assume for now that the return current will take the path of least resistance, as it does for DC. Please check the example below using a ground plane, a source, a potentiometer (as potential divider to ground) and a load.
Will the return current follow the yellow path and basically all of it go from one ground connection to the next in sequence, following the path of least resistance between each ground connection? Or is it more like the blue path where some (the majority?) of the return current finds it's way directly to the source with the least resistance but some of it will return to the intermediate ground connections on the way? Or none of the above?
Also, kind of unrelated but with an inverting op amp summing bus with long pcb traces from each source to the virtual earth point, from a noise perspective, is it better to have the sum resistors at the individual sources or all together at the inverting input? (Do we want the long traces to be at the impedance of the summing resistor or do we want the virtual earth to have the long traces?)
Thanks.
Thanks.
