The fan speed control in my Acura TL stopped working. I traced the problem to the "resistor" unit, which is actually a heatsinked 2SK2500 MOSFET with a couple of resistors, a cap, and a fuse. The drain and source were shorted, so figure it's a bad FET. (Apparently a common problem with this car.)
Rather than pay $50 for a new unit, I figure I'll replace the MOSFET. No 2SK2500 at Mouser, only on Ebay, and I'd rather get a new, better-rated FET anyway.
Can't find a datasheet for the 2SK2500, but I read somewhere that the blower motor has a DCR of about 0.6R, meaning that with a 14V full battery charge it's going to pass close to 25A. (I'll go out and double check the DCR.)
So guessing the 2SK2500 is a 25A part running close to its limit?
This guy is a 50A part and has the same pinout. Any issue with using it as a replacement?
http://www.mouser.com/ProductDetail/Fairchild-Semiconductor/FQA46N15/?qs=sGAEpiMZZMshyDBzk1%2fWi6u8DDnmpUwtW1I%2fhQa5ZHY%3d
