BUILD INSTRUCTIONS
Build Instructions, many different configurations and each requires a different cable length:
Full TASCAM instruction Medium Resolution 13MB.pdf
BACK PANEL CUTTING TEMPLATE
Review the instructions and choose your configuration before cutting back panel. Here is the Back panel cutting template:
http://groupdiy.com/index.php?action=dlattach;topic=47653.0;attach=24380
BOM - Bill of Materials - Varies based on configuration
FOR A SINGLE TASCAM CARD
Quantity 2 of one of the following:
FCI - D25S24A6GX00LF - TESTED
FCI - D25S24A4GX00LF (economy)
FCI - D25S24A6RX09LF TESTED (Preferred - sealed so jack screw holes don't fill with solder)
KYCON - K85X-BD-25S-BR or BRJ should work too (KYCON makes nice connectors)
FCI - 10090098-S254VLF (ultra-economy - includes 4/40 jack screws)
Quantity 2:
50 pin headers (2x25 pin) 0.1” pin spacing pin headers.
No suggested part number - these are very common and often cheaper at the local electronics shop.
Mouser sells 3M version.
Quantity 2
50 pin (2x25 pin) IDC (insulation displacement connectors) connectors. Many
alternatives. No room for strain relief. Part below works:
3M Part D89150-0131HK = Mouser: 517-D89150-0131HK
FOR THE BACKPLANE (Regardless of how many TASCAM CARDS)
Quantity 2:
50 pin headers (2x25 pin) 0.1” pin spacing pin headers. Note that the backplane of the GDIY511x is approx 3.2mm thick. Longer solder tails are better here to get through the backplane (3.2mm). I used normal ones but you need a fine point iron to heat them.
(No suggested part number - these are very common and often cheaper in 10 packs at the local electronics shop).
Quantity 2
alternatives. If you wish you do have room for strain relief on the backplane. This part below works but if you want a strain relief it is ordered separately.
Quantity 1
50 conductor Ribbon Cable 14" to 32" required depending upon configuration.
PCB's
There is a Group Buy at http://groupdiy.com/index.php?topic=47653.msg600084#msg600084. There are extra cards from folks that expressed interest but change their mind. I won't be doing a second run.
Quantity 2:
Quantity 2
Quantity 2:
Quantity 2
Quantity 1
PCB's
