I keep looking at the specs on the new flat screen/LCD scopes and seeing only 8 bit vertical resolution. I can't imagine that being Good Enough....stair steps as I look closely for aberrations when using a square wave test signal and a 60 MHz scope.
IMHO nothing can beat a 'good old' analog oscilloscope!
(I own a PC oriented 'oscilloscope', I think I used it twice from the moment I bought it... I am always using my analog Philips PM3207)
What i am looking for is to mak. Analog measures, bandwidth, crosstalk, etc...the picoscope does all of this, dispite at high frequencies (mhz), is not much reliable...
But i just need measures up to 200khz...the Dso types...not as much functions as picoscope...
But i will see suggestions made here.
JAY X.
I found the refresh rate not to be fast enough with the USB scope I had. Granted, things may be better.
Also, the ground noise from the PC was a pain in audio circuits.
I have a Rigol at home, and have used both the same Rigol and a Picoscope at work, and both were ok. I found the picoscope much better for FFT type things. I've never managed to get a good THD type 1k+harmonics display on the Rigol, though it might be possible with more fiddling.
