Hi guys,
Ok, here's a totally noob question but I'm going crazy here.
For a project I'm using an electret microphone (you know, one of the small standard ones) which I am powering and amplifying with the very very simple standard transistor circuit (schematic attached). I'm using the BC547 transistor.
Everything is working fine, sort of. Audio signal from the electret microphone is being amplified as it is supposed to. It doesn't sound good but it gets the job done.
However, I have to touch the ground connection with my finger in order to avoid a monster buzz sound. This only happens when using the electret microphone, though. If I'm using my laptop or phone to provide an audio source there's no buzzing sounds at all. I recorded a snippet using the electret microphone so you can hear the issue (https://www.dropbox.com/s/z06vdtkpsuwojbh/electret-mic-test.wav). Surely this must be related to a grounding issue but I just can't figure out what's wrong and how to fix it.
At the moment I'm using a standard 9V battery, however I am going to use an external power supply for the final project.
I really hope somebody can point me to a way of fixing this one. I'v been searching the web for days now to find out what's wrong and I know this is an absolutely rookie issue ... but I just can't figure it out.
Any help would be deeply appreciated! Sorry for the noob question... :-[
