In the motor shop I get to check all the caps with an LCR meter ,and have had the chance to measure brand new vs used specimens of the same type and manufacturer . Typically when a motor has been in use for a few years and returns to us ,I see a ten fold increase in ESR and some reduction in uf values maybe 10 % or more. Even though its still works its always replaced , a bad start cap for instance wont provide proper torque when the motor is initially turned on and that causes a heavy current on the run winding until the motor gets upto speed .
Foil run caps also see a reduction in value and an increase in ESR, typically though I imagine motor caps have a much tougher life than inside a tube amp , theres vibration heat and huge current pulses . A few years in a motor seems to have a similar effect to maybe 20 years or more use in a tube based circuit
I think we live in different times now as far as extra mush and hash on the mains supply , its not just 50/60hz and its harmonics and any associated rectification effects , its switching psu garbage ,src dimmer buzz and other spikes ,which can very easliy endup making its way around even regulated supplies and into audio circuitry . If not over the short term it does look like adding bypass caps could help more as your electrolytic starts to age .
