Humner
I've been working on a 12 channel summing mixer to use with the CAPI ACA-BO - which as I understand is virtual earth summing?
I'm at the point where I am trying to work out my summing resistors. Most of my knowledge is based on example - I read schematics and test particular circuits I see in the real world and I have a certain level of practical understanding, but there are plenty of gaps in this understanding/knowledge - anyway...
I see schematics for different mixers and a lot of time they are using different summing resistors - how do I pick what summing resistor to use? I thought it might be based on how many channels, but I've seen 33k used for 8 channels, and 22k used for 16. This is where my knowledge based on example falls apart as I think if you have more channels, then you will want higher value summing resistors. So I think that the 16 channel in my example must have a lower signal level for each channel before it gets the summing resistor?
My main question is, should I aim for a particular signal level after the summing resistor? I have left and right bus channels - what is the best way to extrapolate this for 12 channels?
edit side note: is the signal level not that important with virtual earth summing? Am I on the right track?
