analogggman
Does anyone here calibrate the mix bus comps?
..which mix bus comps in particular?
I always calibrate things like the G10, 22 and 24..
Yes, all stages from input to output.Yeah, any and all
Yeah you are correct. The 1k test tone trick is one I am asking about. Michael Brauer does that and then mixes into his compressors. I was just curious how other people in this forum are doing it.@analogggman - there are a couple of ways to understand your question. Are you asking about calibrating a bus compressor's circuitry so that it functions as expected (ratios, threshold, metering, THD, etc)?
Or is it more about calibrating the levels in your overall signal chain, so that bus compression is predictable (eg 0VU in your DAW is +4dBu in your analogue insert chain, at which point your bus compressor is set to give 1dB of gain reduction on a 1kHz test tone)? If the latter, then sort of - my levels & metering are all set and consistent, but the compressor settings and level of gain reduction vary a bit depending on the track.
Or have I misunderstood completely?
At my side, the bus comp (VCA) is calibrated for nominal level at master insert.I was just curious how other people in this forum are doing it.
Depends very much on the exact circuit.. what are you asking for?
