Hi all.
I just moved into a new apartment, and I am having a few problems. I am not too fond of the idea of messing with the mains installations, but I'd like to know if I'm being paranoid, or if there is something I can do to check up on things before calling an electrician.
I just set up a few things for my work area, turned on the power and got an awful lot of transformer hum. unplugged everything and proceeded to plug in one thing at a time.
It turned out that a tone generator I was recently gifted was awfully loud (output not plugged into anything, so could only be transformer hum
). I tried a few sockets in the apartment, and in the process, it died.
Same goes for another tone generator I recently "inherited", which also ended up refusing to power on.
These two units have two pole power plugs installed with no ground, but I have never had them plugged in before.
I have a pair of powered speakers that are very loud, but they seem to be staying alive. (3 pin connectors). Soldering station also seems louder, but I am not 100% I am not just "hearing things" at this point.
The first thing I plugged in at the new place was a TV, which would not turn on. I assumed it was broken in transit, but now I am not so sure.
This apartment is an attic turned into an apartment, so the installations are probably "new". I think there might be something that needs looking into, but I don't want to be too paranoid, so - anything I can check? Just call an electrician? Chalk the dead units up to ghosts and see if I can get them working again?
Gustav
Gustav
