Seems that you haven't even read my post before replying... So once again:
JohnRoberts said:
The LM833 generic web page is so guys like you get a result when typing in partial part numbers.
Why are the two pages different then? If it is the same chip, it should contain the same information and same packages names. Which it does NOT.
If the LM833 is a generic page, then please show me the LM833N listed on that page. According to your assumptions, it should be there listed between the packages there. But it is not.
JohnRoberts said:
At the end of the data sheet there is a list of full part numbers with package types.
Yes, and there are listed DIFFERENT full part numbers for the same packages of LM833 vs LM833M
for LM833 it's:
LM833D = SOIC (D)
LM833DGKR = VSSOP (DGK)
LM833DGKT = VSSOP (DGK)
LM833DR = SOIC (D)
LM833P = PDIP (P)
(NO LM833N LISTED AT ALL ON THE LM833 WEB!!!!)
for LM833M it's:
LM833M SOIC (D)
LM833MM = VSSOP (DGK)
LM833MMX/NOPB = VSSOP (DGK)
LM833MX = SOIC (D)
LM833N = PDIP (P)
(i excluded the /nopb versions which are the same)
So how do you explain that?
If LM833 and LM833M is the same chip, then why is its SOIC version called LM833D on the LM833 web page and LM833M on LM833N web page?
Why LM833P for DIP of LM833 and LM833N for DIP of LM833N?
Same for VSSOP packages.
Perhaps because it is a different chip?
It even has different parameters.
Please explain (perhaps using reasoning instead of phrases like "guys like you"
JohnRoberts said:
If you try to buy a LM833 without the rest of the part number they probably won't let you, but try it and tell us what you get. 8)
But I never said that there is a physical part called LM833. Read my post again. I said that there is LM833 kind of chip, of which there is a physical DIP type named LM833P (and not LM833. i never claimed that), and then there is LM833M kind of chip, of which the DIP kind is named LM833M.
So it's two chips. If we consider only DIP packages, then the physical parts are called LM833M for one and LM833P for the other.
JohnRoberts said:
PRR gave comprehensive and correct advice, as usual.
PRR gave very nice piece of information which applies to 99% cases, but not this one. Or if it does, then prove me wrong using reasoning.
I can see that he's experienced, but that doesn't mean that he can't make a mistake and it also doesn't mean that we should stop thinking when he speak and stop questioning what he says even when we think he is wrong in some case. And also the fact, that I have only 5 posts in here, doesn't mean that I'm an idiot.
