speakercoil said:
There are very few people who actually make their own capsules... The ones I can think of are... Beeskneez, Korby, Peluso, Thiersch (who doesn't build mics just capsules), Flea, MBHO, and Tim Campbell (only makes capsules)...
There's also Dale, Marik, and Burdij, and others I may have left out.
As far as Peluso making capsules...from what I can tell, he gets stock Chinese capsules and tunes the resonant frequency of the diaphragm.
There's an NPR interview where you can hear him doing it with a can of compressed air.
So, if this is true, then I would not call that "[making his] own capsules."
Of course, I could be entirely wrong about that, and I welcome Mr. Peluso to correct me.
From what I have heard, he sounds like a nice guy.
You may have already read some of these:
DIY capsule
Getting gold onto diaphragm
My latest capsules
Capsule construction. the practical aspect
aluminum vs. gold vs. nickel vs. brass plated caps...
Building capsules
I think that to make a great capsule, you will need to jump in, as someone said, and experiment with several designs and construction techniques until you figure out what works and what does not.
But before you can begin experimenting, you will need the equipment to construct the capsule.
-Lathe and/or Mill (CNC or at least with an XYZ readout)
-Thermal evaporator or sputtering system
-Tooling & Jigs for milling, assembly, and tuning (this will take a little ingenuity, as you will likely be "inventing" these to some extent)
It's expensive to tool-up for capsule creation.
[Some duplicate info in this post...just thinking out-loud.]
