CD4007 what’s ifs
Help Support GroupDIY:
AVA
Canada
Hi all, I hope you’re well…
I was messin around in the old electronics supply store and somehow on the massive wall of ICs a humble CD4007 caught my eye. I looked it up online and saw that it’s a little bundle of complimentary MOSFETs. For some pocket change I bought a few to play with. Why not.
looking online, I see a lot of talk of these being used as CMOS inverters, which I’m still unclear on, despite my research.
I found some other folks that turned it into a guitar pedal, but I think it was really just a class AB amp in a small enclosure…not sure.
Anyway , I’m wondering what you folks could make of this! Any use inside an audio circuit?
Could we do anything creative with it?
I know that P or N channel MOSFETs can be used as clipping diodes by shorting the gate and drain (picture attached). Is it possible to turn this thing into a pack of clipping diodes then?
Poking around with the diode setting on my dmm gives some interesting results…that my inexperience cannot explain.
Could it be pressed into service as a beafy input and output buffer?
Just a thought experiment…And a bit of fun!
Cheers!
JohnRoberts
Staff member
Moderator
Hickory, MS
Back in the day the CD4007 was handy... Being able to mix and match the CMOS devices to make oscillators or whatever. You could even trick the simple inverter pair to look like an inverting amplifier. Of course when you try to trick the inverter to act like a linear amp you need to be careful about using too much rail voltage, because both pull up and pull down turned on at the same time can exceed package dissipation. For modest rail voltages it works OK.
AVA
Canada
Interesting!
Thanks JR.
An oscillator would be kinda cool! Is it possible to get more than just a square wave out if it? I know the clever use of some capacitors and resistors could round the corners a bit, but I'm wondering if we could somehow make a functioning sine wave LFO...
JohnRoberts
Staff member
Moderator
Hickory, MS
It's relatively easy to make a square wave oscillator, sine wave not so easy, clean sine wave, don't bother.
One could attempt to use an inverter pair as a gain stage it would have poor open loop gain and rather uncertain DC performance compared to even a cheap op amp.
For voltage or current controlled LFO perhaps check out OTAs (operational transconductance amps).
AVA
Canada
Thanks JR,
OTAs are definitely on my list. I was working my way through filters and gyrators before the CD4007 set me down a different path.
JohnRoberts
Staff member
Moderator
Hickory, MS
Messing with the CD4007 is close to designing with discrete mosfets. I am a little surprised they still sell them.
AVA
Canada
It's an old store haha, but they do seem to be active parts on Mouser...
I'm trying to think of it as a set of discrete MOSFETs, but the pinout is doing my head in. It looks so basic at first, but in practice I can't seem to get it straight.
It'll take some fiddling.
rackmonkey
Texas
I’ve used the 4007 for the bypass circuit in pedals. Lower parts count as you can do the flip flop and actual switching with one IC.
AVA
Canada
Hey that's a great idea!
Thanks for posting.
Do you happen to have anything drawn up for that?
JohnRoberts
Staff member
Moderator
Hickory, MS
Another benefit is that the MOS transistors on the same substrate will track and behave similarly.
I repeat the caution I already mentioned, when attempting to trick CMOS pairs into linear operation, too much rail voltage can easily exceed device dissipation from parts pulling up and down at the same time.
MisterCMRR
Ventura, CA
As I remember, the open-loop gain of each inverter is about 10x and you can run them easily in self-bias to make a high-gain AC amplifier (I've used this at the front end of a phase-locked-loop, for example). Just connect the opposing drains in stages 1 and 2 the same way they're internally connected in stage 3. Then put a 10 MΩ resistor from input to output of each inverter stage (this makes in and out sit half-way between rail voltages. Then AC couple input signal to stage 1, AC couple stage 1 to stage 2, etc. So overall gain is now about 10 x 10 x 10 = 1000 ... and will do rather soft limiting. They're very handy little parts.
And you can do all sorts of amazing tricks with OTA (transconductance amplifiers). I've done intentional slew-rate limiting, which can be changed by varying the bias current). And just putting a capacitor as load on the output and using with a pair of comparators, you can build a perfect triangle-wave generator and vary the frequency with bias current. And lots more ...
AVA
Canada
Wow! There is so much to unpack here
OTA's are another thing that I'm slightly obsessing over right now. I just ordered some LM13700 and NE5517's. We'll see what happens. I read in some dark corner of the internet that OTA's are slowly dying? Is there a chance that they'll be non existent in the near future? That would be foolish, no?
I'm going to try and put together this high gain AC amp using the 4007. I'll probably read that post 900 times in doing so haha. It's my attempt at finishing one thing before starting another.
Cheers guys! Thanks for your time
JohnRoberts
Staff member
Moderator
Hickory, MS
4007s make low gain AC amps...
I used lots of OTAs last century... these days it is cheaper and easier to do it digital. But IMO it is worthwhile to understand analog first.
gyraf
Staff member
Moderator
Aarhus, Denmark
- and as bypass "relay" in e.g .the TC 1140 equalizer:
