[quote author="bcarso"][quote author="mojotron"]I don't have any CD4049UB ICs, And I used a 14049U as an alternative without the best or results in a distortion circuit.
I'm wondering if anyone has found a good alternative to the CD4049 in a Tube Sound Fuzz kind of circuit?[/quote]
The MC14049 should have the same performance as the CD4049, so you may be having some other problem. But, there are a few cases where the Motorol* (now On Sem*) parts are a bit different (for example different manufacturer's 4016 parts can be markedly different), so maybe there is a slight difference here as well.
The CD4009 requires a second power supply voltage on pin 16 to work. The 4049 leaves that pin unconnected internally so it is a drop-in replacement for most apps. But going the other direction would be unlikely to work.
The salient properties of the 4049 compared to a standard hex inverter are that the input voltage can exceed the power supply a bit nondestructively, and the output can sink 3.3mA down to 0.4V guaranteed, thus can drive two standard TTL loads.[/quote]
Thanks for the replies. The circuit with the MC14049 in it just sounds a little off, perhaps I will fiddle with the FET driver for this circuit, but I think I will take a good hard look at the datasheets and see if anything pops out at me.
