I see a few cheap coil winders on ebay ,
Im wondering if say a 60mm motorised fader could be used as a wire feeding mechanism on a basic coil winder ,so as to make precise layer winding possible , maybe for finer gauge wires at least. Cnc winders cost around 600 .
Even a basic hand driven winder with a sensor on the main shaft ,then a processor /driver to tell the the motorised fader the correct position wouldnt be too difficult ,could also easily be integrated into the semi automated winders costing 100 pounds or so.
the interface need be no more that start point/end point and a way to set the wire gauge or amount the winding is displaced each revolution of the bobbin
https://www.youtube.com/watch?v=FIOocMoRsYQ
