rogs
The adaptor I've been using with my DMM to test transistors is shot....The contacts are very 'iffy', and you have to present the component in the correct orientation.
It's always been a pain to use...now it's worse!
Looking for something to replace it, I came across this: https://www.aliexpress.com/item/1005005202074391.html
At the time it was less than £40 ($50) including tax and shipping ... so I thought it was worth a pop...
And I've been pleasantly surprised. Component testing via a DIL ZIF socket -- and inserted in any orientation ... much easier!
Plus -- a simple battery operated 'scope and a signal generator -- and a simple volt meter.
The 'scope worked better than I expected - only 500KHz bandwidth though.
Nicely presented - rechargeable lithium battery.
MCX connectors not my first choice for 'scope leads - you really need a MCX to BNC adpaptor, but htose are not expensive.
Useful little device to chuck in the toolbox -- and it's a really nice change to use non-oriented ZIF connections for component testing!
Can't really go wrong at that price....
