Just to warn everyone, I'm just a hobbyist... ;D
I am going to try to build a controller that sends signals down a single cable to a bank of solid-state switches, which in turn will run a lighting relay. This single cable format is a necessity for what I am doing, as I am using an audio signal.
What I want to do is put band-pass filters on the switching end, so the signal frequency will determine which switch is activated. These signals will be in the audio-frequency range. I will only have to have three bands: X < 500Hz, 600Hz > X > 2kHz, and X > 3kHz.
Since I am not concerned about the sonic integrity of the filters, I thought I might ask if anyone has ideas on how to build the filter out of the cheapest, most readily-available parts.
The signal output stage will be a headphone-level out.
