Cheapest input Transformer for API 312 type
Di_Sousa
GDIY Supporter
Portugal
I'm looking for the cheapest alternative solution for input transformer on an API 312 type preamp, something that worth 5-10 Dollars or less would be great.
Any ideas?
W
mjrippe said:
That would be the 2622, right?  Listed as 150/600 primary, 10k secondary.  Edcor COM14 fits that description for $5.01.  http://www.edcorusa.com/p/868/com14
I supose so. Thank you so much
Have to see if I can get Edcor in Europe.
Any place or brands in Europe for cheap Audio Transformers?
I have use two small Beyer 1:10 and they sound good. You can also try 1:7
You find them sometimes on german eBay.
For 2 of them I have paid 20,00 Euro. Sometimes more, sometimes less.
Andreas
Andreas
Thanks Andreas, the API 312 want to have a 1:7 or 1:10 at the input?
orig. 2622 is
1:3.5  Series Primaries
1:7    Parallel Primaries
24-25 EE nickel lams
CJ said:
orig. 2622 is
placed an original, real 2622 on the bench.
0.1 VAC @ 1000 Hz into the high Z side.
.0122 VAC on the low Z windings, strapped in parallel.
Same test @ 10 VAC in,
1.24 VAC out.
No appreciable loading in the test setup.
Suggests a 8:1 to me.
Gridcurrent, you are probably right, the one i took apart had a broken sec so i could not do a ratio test, also, it was cased in very hard black epoxy if i remember right, (been 10 years), so counting the #50 wire was no easy task so i probably counted short, came up with 1 : 7.12
can you check some things on that guy, like sec DCR?
and maybe put a 20 Hz into the sec and measure the current at about 1 volt AC?
thanks! i will put up a blueprint if i can get a few more parameters supplied,
cj
here is a doc i found at dan alexanders site,
this would seem to indicate a 150/10K = 1:8
or a  600/10K = 1:4,
maybe put a 10 K load resistor on that 2622 and see what the turns ratio is,
    82.4 KB
