Just incase anyone interested I built a mic a couple years back, circuit was as maxes MK47 ie 2 X 6028 tubes philips in this case I didnt use a PCB board I did point to point not even a tag board, power supply was max desighn too 105V & max OP transformer, I used a equinox body and the most important part the capsule its a Violet design Vin 67 its was about £500 on sale a few years back it was in a lollypop head, its meant to sound like a U67 mic, I dont have a real U67 to say that it does or not but the capsule when used on Violets own flat solid state mic body is said to sound like a U67 its got good reviews..... so basically its a quality capsule but its not gonna sound like a U47 for sure.
Yesterday I soldered together Olivers alternate U47 circuit I used a (well 3) Mullard EF80 I swapped out the MK47 electronics even left the same OP cap a russian paper in oil 1uf, I modified the power supply added extra PSU for the filiment 5.05VDC.
before changing circuits I recorded vocally a verse of a song with MK47 & then same verse with the AMI I tried the 3 Ef80s I had
Result well to my humble ears if im honest I couldnt hear a difference, if there is difference its so small that I could sing a different take to make sound different, I kinda expected this result as I believe thru many experiments like this that the capsule is way by far & I mean miles the most important component of a mic, I know transformer is fairly big part & head basket next op capcitor.... after both these circuits were based on and designed to sound like & behave like U47 circuits so both guys did good job i guess.... I like the sound of my Vin 67 in either circuit I prefer it to my real U87ai tho I would love to get a real K47 K49 M7
( by the way I have ordered a real U87 transformer to add to a vintageU 87 circuit I already build & I will add my 87capsule in its head basket so I can AB U87ai Vs vintage style U87)......coming soon.....
