living sounds
I found elevated THD in a channel on my console and was able to narrow the problem down to the input section. Because of many changes to the circuit board over the years there are a lot of repaired traces etc., so I started resoldering, and also switching out parts to find the culprit. Then I accidentally left out the servos capacitor for a test run and was baffled to find the low end was still all there and the signal was amplified 1.3dB across the audio band. I re-checked all the connections around the servo and couldn't find a fault. I then tried my Spice simulation and even experimentally removed connections in Spice, but couldn't replicate the results. With the cap removed the low end should obviously be gone, the simulation reflects this accurately, of course. With more connections severed I couldn't get anywhere near the +1.3 db difference of the channel without the servo cap to the working channel.
I'm at my wits end now and would kindly ask the wizards here to give me a hint what to do. In the attached schematic C9 is the cap I removed. Thanks!
