Hi Iv being trying to DIY the best vocal channel I can for the money, I have DIYed many tube pres and some tube limiters & have come to the conclusion that a BA6A limiter is the best sound Iv ever heard so I will use just that, all the pres have there merits, so I want to use them all however some have level control which is good, & others dont & I need to tame them before the limiter does its bit..trying not to use pads.
I have Sowter mic transformers 9045 on my tube pres that sound great but for the hotter pres without level controls ect V72, BA21A, Mcurrdy A300
I think I need maybe lower ratio trans...
is that wise ?
I have a little tran from a audix transistor pre ,seems to have lower ratio than sowter I also have a OEP A262A3E but am not sure I understand best ways to wire it ?? if anyone could give me some pointer that would be good
I want to make a means of plugin in different trans to different pres..
That brings me to my next questions...upon reading here about the A262A3E tran, I read about Zobel networks & stuff, sadly i find it quite hard to understand lots of the techy stuff thats here but im trying & I like to experiment & use my ears...some 1 was experimenting putting different resistors across the output of the tranformer ...
I put a 200K pot across the output of one of my transformers Is this not good idea to leave it there to control the level to the pres ?? I dont no how to use my scope yet but to my ears it sounds pretty good still.
I have a Gardners GR118066 AF matching tran Pri 6.25/25K Sec 100K .......
Can I use this for anything ???
Also a RCA MI12399 pri 250 Ohms centre tapped Sec 50K 1:14 ratio...what could I use this for ??
Thanks for reading sorry the what might seem to you silly questions
Many thanks .....................Gary O.
is that wise ?
