Hi all,
I’d like to control a set of VCA’s from about 25m distance.
What’s the idea? I’d like to offer musicians a possibility to alter three stereo elements of their in-ear mixes from a small remote attached to their music stands.
Instead of sending three stereo balanced signals to their remote, which would cost way too much cable pairs, I’d make a box which takes three stereo inputs, have them pass sets of VCA’s that can be controlled from the remotes and then sum these three mixes to one final mix, that enters their in-ear wireless systems.
I know great care should be taken to drive the control ports of the VCA’s with a noise free and very low impedance signal.
Ideas that come to mind (not necessarily inspired by technical knowledge…):
a) Send a way too high DC voltage (eg +48V) to the remote, put it on the top of three potmeters and send the wipers back to the VCA’s; then rescale the voltage using a resistive voltage divider, then further on thru a control port buffer.
b) Instead of the above, use 3 three-pin voltage regulators in the masterstation to drive the voltage divider and use the remote pots to set the voltage (connected between Adjust-terminal and GND via long cables)
Is any of the above possible? Would a voltage divider do for rescaling the control voltage, or is a more esoteric approach needed?
In the end the VCA’s should be adjustable from 0 to -12dB attenuation, with the center point of the pots being -6dB. So the talents have a mix range from +/- 6dB.
Rogy
Rogy
