Walrus
How would I go about working out the size of choke I would need to reduce switching noise on the output of a
15 Volt 20 Amp 70kHz SMPS?
Presumably the common mode choke is for the input in which case you need to know what the input current is which is not the same as the output. Then find parts that handle double that.How would I go about working out the size of choke I would need to reduce switching noise on the output of a
