Nightmusic
Member
- Joined
- Oct 21, 2014
- Messages
- 22
Hello everyone,
After checking everywhere on the web, I’m still having some difficulties finding correct cable pinout for my Telefunken/TAB W395a german equalizer.
To be more precise, I do have schematics which clearly show the original pinout, but since the connector fitted at the back of my unit is not original (the previous owner probably recabled his own way with a different kind of connector), i have no reference regarding correct pinout with the original connector anymore (which original connector i finally found on ebay though)
So before putting original connector back in place and going into adventurous path with resoldering, i thought i could rely on the cable colours as a proper reference, in case of course someone could help me retagging each one of them, according to the original connector pinout order.(Besides red and blue cables which obviously speak for themselves, that’s actually only 5 cables left to identify)
So i attach here a pic showing the actual cabling between the pcb and the non original connector of my unit, so if anyone could spy a bit into his own unit just to check which cable color correspond to which (original) connector number, that would be just awesome!
I guess, just knowing which pin number corresponds to which color would be more than enough for me, since i already have the original connector pinout, so i could then draw my own conclusion about each cable function.
I hope i did it clear enough with my explanations…anyway, thank you very much by advance, dear DIYusers!
