klem
So I have some Neumann KH420s that to the best of my memory, are front face heavy vs back side when you remove the amps for a soffit mount. In order to simplify decoupling process, it seems best to counter balance the speaker in its box via additional dummy load rather than determine the different load ratings at a given location. This is not a cheap speaker, so I need to be very careful to ensure no tipping in this process.
Any suggestions on a methodology for adding counterbalancing weight?
I am thinking a small 2x4 block (or better yet curved/domed shaped supports of some sort) centered under speaker and box, observe tipping direction and add weight above box, then progressively reducing the size of the support underneath as I maintain a more equally distributed weight / not tippingcentered load? I don't have access to scales that can determine the weight footprint at any given area for an unbalanced box, though that would certainly be nice to have.
Thanks for any helpful suggestions to help me think this through...
