ruairioflaherty
abbey road d enfer said:Latency is a problem in real-time applications only. Mastering is not a real-time application, neither is mixing. Broadcast very often is not real-time, since may broadcasters have a permanent 7 seconds delay-line called profanity delay. Recording and concert sound are real-time applications for which it is impossible to delay the main path in order to leave enough time for the side-chain to do whatever it has to do.strangeandbouncy said:Hi,
fascinating stuff! It's interesting to hear of that digital sidechain. It makes perfect sense, I guess, at least in terms of processing data . When you say "Low Latency", even at 384kHz, in mastering, especially disc-cutting, any latency must surely be a serious problem, no? I am sure that broadcast applications must be very critical in terms of "instantaneous" limiting. In the analog domain, latency is not a problem, I surmise( with high slew-rates anyway(?))
Interestingly George has plans to use the same sidechain in both a plug in and hardware piece. In the hardware piece a VCA will control the level with the digital sidechain. I use some high latency plugs in my mastering work but the challenge with the digital sidechain controlling an analog piece is obviously that one doesn't want the audio event to have passed before a sidechain can pass control info to the VCA.
