finally figured out what was wrong with this xfmr that somebody sent me a while back,
i believe this is an API type output, quad wound, we will take it apart and see,
problem was a short between coils, an unlucky short, red to yellow, 2 Finish leads that were supposed to be isolated were tied together, which means if you series connect red to orange, you will be shorting out the org-yel coil, these things are like resistors, brn is a start, red is it's finish, org is the next start etc,
here is the Main Offender, which is also a cool album by Keef Richard>
