jetboatguy
Old transistors:
input section has:
2N508A x 5
2N527 x 1
output section has:
2N4250 x 4
2N697 x 1
2N527 x 1
I was wondering if I could swap some old transistors and sonically improve my mic preamps with modern transistor replacements... is this a waste of time ?
I have 4 x Scully 280 channels that I've overhauled recently... so far I've wired in a newer power supply, 24VDC from McCurdy Radio Industries and I've also re-capped every single electrolytic in each Scully amp/unit... aprox' 110 caps !!
Here's the schematic to the Scully 280... notice the squares with broken/dotted lines in the scematic, each Scully amp has 3 removable audio PCB cards that plug into it's own edge connector... the (record amplifier card) holds the mic pre circuit with some transistors and eletrolytic caps... the line out driver section is in the (playback amplifier card)... and the (bias/erase oscillator card) is removed from the unit, it has no function to the mic preamp duties.
http://web.telia.com/~u31617583/Scully%20280%20audio%201.jpg
http://web.telia.com/~u31617583/Scully%20280%20audio%202.jpg
input section has:
2N508A x 5
2N527 x 1
output section has:
2N4250 x 4
2N697 x 1
2N527 x 1
