Hi folks,
I'm looking for a current amplifier circuit or topology which is simple to integrate. That's the background of the story:
- 2 x 4 channels of current amplifiers for an actively controlled monitor system
- 2 x 3 channels need to provide approx. 25W RMS to a minimum impedance of 5 ohms under steady state conditions
- 2 x 1 channels require approx. 50W RMS assuming the same load
- the 25W channels should if possible operate in Class A to avoid the hassle of compensating for crossover distortions and the need for elaborate phase inverters
- ideally, readily available ICs should be used for the sake of mechanical and thermal simplicity
I know this is not the kind of topic commonly discussed here, but I'm shure some of you will have some very useful suggestions. As to why use current amplifiers? Simply because they effectively circumvent the dominant source of non-linear distortion in direct radiator applications for monitoring systems - voice coil resistance changes. Given strict adherence to minimum-phase behaviour of the driver, the old objection of insufficient electrical damping is irrelevant as equalisation of the occuring transfer function peak near the resoance frequency solves the problem.
Cheers: Sven
Cheers: Sven
