SIXTYNINER
Apparently it looks as if it was done on purpose ,
but it could also be.....
post your about ,
(..if you like)
cheers .
post your about ,
(..if you like)
cheers .
I guess you better go re educate the people who came up with the term...digital audio.audio is analog....
howard dumble did the fet input thing on his tube amps. Never heard anyone complain about anything dumble did other then the price tag for one of his amps.Back last century I whispered into the ear of a junior guitar amp designer, why not try using a very low noise JFET input stage for a guitar amp input? He asked me why, so I replied less noise, then he repeated why? The noise is how guitarists know the amp is turned on.
So cool it's now called dope30 years with Cubase and I'm still learning the thing. How cool is that!
......something like a Pultec eq plug in sound as the original vintage unit ?We look at what I am working on to decide what pipeline is neccessary to acheive sonic resolve.
In the event it were an 11th hour client mix for say a tv episode then working in the box makes the most sense. If I am working on something personal it would be tube driven. In regards to what sounds better, that depends on the end user. All I can do is make sure it sounds optimal.
post your about ,
(..if you like)
cheers .
I've seen these type of comparisons before, in my experience, people pretend to be impartial, but they always try to tweak things as much as possible in the ITB mix to make it sound dull, and as much as possible in the OTB to make it sound good. For example, they will take the mix to the outboard gear and work on it for a long time to make it sound as good as possible, whilst leaving the ITB mix as it is. And they latter pretend that is a fair double blind test. If you are going to saturate the OTB mix, you should also saturate the ITB mix, otherwise, that just proves saturation sounds good, not that a TEAC mixer is magical.
You are absolutely rightPlugin makers will do the reverse
