Purplenoise
- Joined
- Sep 19, 2019
- Messages
- 531
Usually 47 capsules have a dip around 6/7k. Have you tried another capsule? Have you flipped the capsule to use the other diaphragm? Also c1 cap plays a role. If you use styrene it will be a little brighter than a film. Phillips/Mullard mustard caps will give you more apparent midrange.dasnevestheo said:Hi there, been using my DIY U47 for a few weeks now and the sound is almost perfect to me
However, I get quite a bit of sibilance and find the 7kHz area quite strong compared to other 47 style mics.
Any advices on how to tame this beast ?
Body : Alctron
Capsule : Beesneez K7b (wired in cardio only, no switch or relay)
PCB : acrylic board / point to point
Tube : Siemens EF80
Transformer : AMI BV08c
Output caps : 2x K42Y-2 PIO Capacitor
PSU : Dany's PCB, set to 105V / 5.05V
Cheers !
