And if you are that worried about it, why not just record at 96 kHz sample rate?
Counterintuitively, time domain precison is linked to bit depth rather than sample rate.I have generally preferred 96k to 44.1k. It's also more accurate in the time domain. So just settled on it as a default and haven't looked back.
https://science-of-sound.net/2016/02/time-resolution-in-digital-audio/
As for 44.1k vs 96k - it depends a lot on the converter and there are always trade offs. Lower sample rates often are better in terms of jitter. On the other hand, good filters are easier to construct for higher sample rates...
No filter would be a very bad idea IMO. My DACs use two cascaded digital antialiasing filters, one high in the ultrasonic region, and the other one below Nyquest. The ones loaded into my DAC make very sure no aliasing happens, these are linear phase filters and even filter out signal far below Nyquist, ranging a little into the audible band. So they are the opposite of the steep digital filters you find in most modern DACs. They are the only filters that lack the artifical mix of midrange aggressiveness and veiled dynamics that plague most digital playback today. There is no plausible correlation of these audible differences with actual measurements, since the measureable differences are almost completely out of the audio band. Signals coming from the DACs with these filters react better to processing and produce better end results in the mixing process.Iirc you are partial to R2R type DACs with no filter? There is no right or wrong when it comes to preference.
You can upload NOS ("non-oversampling-filters") into the DAC, which means no filters at all. As a result you get a high end boost and mirror images potentially causing problems with stages not designed for it. Percussive signals sound very alive, but it is a deviation from the source signal. It can work as a "sound" though (I seem to recall that the Fairlight samplers worked via this principle).I did read somewhere regarding the no filter thing. The premise was the electronics and speakers themselves are a LPF, if the image is high enough they would then do all the heavy lifting for you. Seemed interesting.
