Hi. Sorry to bothe you all, but I just finished DS87 build, and the result was silence. I dind certai connections a bit confusing, that is first the connections of the AMi T13 transformer, and the 4 capsule wire. Any advise about that?
you need to take a multimeter, turn on the phantom 48v and start checking the circuit from XLR to JFETHi. Sorry to bothe you all, but I just finished DS87 build, and the result was silence. I dind certai connections a bit confusing, that is first the connections of the AMi T13 transformer, and the 4 capsule wire. Any advise about that?
black -> p+The yellow pair measure 23R and the blacks 449R? The yellow seem to be secondary, but is there a negative and positive side?
