Svart
I'm starting to investigate a discrepancy in some designs here at work. The part's datasheet shows a NPN darlington used in a variable voltage circuit for varactor tuning. Our design uses a standard NPN in it's place.
For some more background, this is part of a varactor tuning circuit, 0-27v varies the frequency of the oscillator tank circuit via the varactor.
I've not done much work with darlingtons and wonder if any of you great analog designers can give me some real world insight in any quirks they might have and any typical noise profiles over voltage/current for both input and outputs. I get a slightly noisy output the closer to 0v I get using this circuit.
