Travis1000
Hello all, after tinkering with this on and off for a few weeks now, I am calling in for reinforcements! This is my first build, and after some initial cold solder joints, I got the mic up and running. After using it on a session or two, I noticed the mic pre needs to be all the way open to get signal that approaches 0VU on my DAW. This doesn't seem normal after reading other peoples responses to this mic. After reading this thread (http://www.groupdiy.com/index.php?topic=46396.0) I double checked my voltages.
At pin 2: 90V
pin 5: 5.8V
pin 1: 36V
According to the schematic in Dave's article, the voltages on pin 2 and pin 1 seem a bit low. Would this be the cause of low output level? If so, what would cause the voltages to be a few volts low?
I am doing two things differently than the article suggests. 1) I am using a Shure KSM109 as my donor mic, which I think is mostly irrelevant. 2) I am using a Cinemag CM-11021 (http://cinemag.biz/mic_output/PDF/CM-11021.pdf) which is what the folks at Cinemag suggested when I e-mailed them.
here is a link to download the original article.https://www.dropbox.com/s/r046jjs1v01jzwl/Another%20Tube%20Microphone%20From%20Barstow.pdf
Any guidance and suggestions would be greatly appreciated!
At pin 2: 90V
pin 5: 5.8V
pin 1: 36V
