Hi Silvas - i,ve used the parallel switch - printer - boxes for switching 8 way audio cables with decent results.
I used 6, 2 way boxes to route a desk between 24 track tape and motu 24 channel DAW.
All ran balanced with good results.
If you want to go overkill - you could open up the switch boxes, remove the signal wires and replace with short balanced/screened jumpers - but i don't think you'll see much improvement.
I was also asked to implement switching of a 24 track tape between 2 control rooms.
Money was tight, so i got 2 pieces of dexion shelving uprights - you know, the angle iron that has holes on 1"/25mm spacing - bolted these to the side of the 2" tape machine,
Got 48, 3 pole double throw minature toggles, loaded them into the dexion strips (8mm holes - perfect!). Used 3 x 3m 8way xlr looms cut into halves for tape ins and outs on the 24 track. Wired these to the switch poles - 1 strip top to bottom for tape ins and the other for tape outs channels 1 to 24. 3 poles being hot/cold/screen.
Then wired each control room looms to the opposite switch contacts.
Used the angles side holes to tyrap all the multicores to the strips.
It takes about 20 secs max to flick the 48 toggles - much quicker and easier to wire/repair than actually using something like 2 90 way edac to swap!!!
Dd this over 3 years ago - both studios share the live room and tape machine - used virtually all year round - not been called out to it yet!!
Didn't get any pics - but i'm going there soon to record so i'll try and get and post some pics for posterity!
