tubejay
New member
I'd love to repair this myself, but I think it might be outside of my ability to do so. Does anyone know anyone who works on 900 series gear? This one is tough because of all of the power rails going into it. I have a bench power supply, but I think I'd need another just to power it on outside of the 900 rack.
Problem: It doesn't pass any audio when the circuit is engaged. I think the problem is in the audio path, because the oscillation circuit etc seems to be doing exactly what it should. I can adjust the controls on front, and if I crank up the output on my mixer/mic preamp, you can see the speaker actually moving along with the changes in the controls at a very low frequency, and it's slightly audible, though no audio passes from the input. So I think it's a problem with the audio portion of the circuit. I'm thinking maybe a bad transistor or opamp somewhere?
I tried a basic recap and that didn't change anything.
These things are pretty rare, so I'd love to find a way to fix it or even pay someone else to fix it. I just hate to see it go to the trash, when it's probably something simple. The schematics are readily available, I just can't really test voltages because I can't power the thing outside of the 900 rack.
I guess my next step it start pulling and testing transistors and opamps. It just seems like a lot of extra work and a total crap shoot to do it that way. Not to mention the strain of desoldering everything on the circuit board.
