when you say "eastern successor", I am confused! The AC761 IS the "eastern" (ie DDR) successor(well, read pale imitator) of the AC701, made by Telefunken in West Germany . . .
Have also read the PDF at Jogis Röhrenbude und thought it might be an usefull alternative for an tube amp.
PRR: Do you have calkulate the schamtaics or have you already tried it in reality?
This is an inverted triode in which the grid and anode are swapped. However, it can be used as a triode (see picture). The system is identical to the DC960 = AC761 = AC701, but directly heated with 1.1 volts. So it is comparable to the Hiller MSC1.2 (1.2 volts directly heated).
Since the Hiller MSC1.2, MSC2 and RFT DC760 / DC762 are all directly heated, you need a very good power supply. You also have to pay attention to the positive and negative pole of the heater, otherwise you will have a louder noise.
The DC762 can be used in a triode circuit as a replacement for a Hiller MSC2 or Telefunken AC701 without any problems. Of course, you need an additional series resistor for the heater. And more space, because the tube is 2 cm longer. But this is no problem in the Neumann M49 and M50 as well as in the CMV3 and B-V30 bottle microphones. Unfortunately, this tube does not fit into a small-diaphragm condenser microphone like the KM54.
