Hi to all!
The topic name says all. I can agree with use of dc/dc working on frequency over 200 khz, even in this case,
regulation and output impedance isn't as good as canonic power supply's.
For example.
I measure -88db noise rev 1V AC without any weighting filters on my Sontec power supply +/-24V done with LM317/337 and loaded 80 Ohm/5W resistors (300 ma).
I can measure in best case -67 db weighted on output of 1W 5->+/-15V $12 dc/dc converter.
Soooo....
I proposed an easy test here:
So, let's open the discussion.
For example.
Soooo....
Igor said:He! Cannot pass it silent. Great source of amusement, aye.Balijon said:It was not my intention to offend anyone, if I do, I excuse.zayance said:@Balijon: Sounds kind of rude?,
@Igor: I have a great respect for your work, craftmanship and contributions! I hope you take my humor mildly.
On the subject:
I try to think different, as an engineer. I look at the 500/51x platform as a very cumbersome way to hook-up 2 XLR's and a power-feed. (Again no disrespect!)
Especially the exotic connector we use and the fight to support different voltages (like 24V and tubes) within the infrastructure.
I always look for simplicity, it would be a great flexibility if would just convert on the print what we need to power a specific design and use a common available (consumer-priced) widely available adapter, that is not critical in the performance. This is what Rupert Neve does in his Portico designs.
Look at your mobile phone and the adapter-nightmare we had to put up with for years! I am very happy that this has been regulated in Europe now. I am extremely happy that I do not have to rebuild my car when I switch phones...
DC-DC converters have another advantage: Classic power-lines are sewers of the audio signal, transmitting garbage from module to module, a super highway for dirt transport. The effort we put into isolation through input and output transformers is for keeping our signals clean from polluting dirt. DC-DC converters are transformer Isolated and do just this for the power-lines.
Yes, they are switching power-supplies that can introduce harmonics because they switch on a high (in-audiable) frequency. But you will notice in a bad design (same as a bad grounding design). I is a mature and affordable technology that is applied in many things that surround us and we use on a daily basis.
I think that we should be open for the merits it can bring us, if we understand how to apply it well.
I think it is too simple to only have 'religion' and tradition disregard this.
grT
Cumbersome or not, matter of personal taste.
DC/DC converters: open your own thread and discuss it. You will find same mind experienced people of course.
For the start.
Find clean dc/dc converter for less than $20/watt, running at over 200kHz. A?
Usually they use 60-100kHz. Not as easy to filter out.
BTW in case if more than 1 converter used they should be synchronized to avoid interference.
After all. Why not than use high efficiency Ge photoelements and ultrabright led's.
as an engineer
Yes, of course.
Do next. Use 9k+1k in attenuator to get -20 db of audio signal, than, bring back the gain with single opamp say ne5534 and 9k+1k feedback r's, 22pf for stability.
Use all possible filters and feed the power from $10 5->+/-15 dc/dc converter; measure the s/n with soundcard; than feed the power from simple +/-15V supply done on 78/7915;
measure the noise again. Than do it with analyzer with and without weighting filters. You will discover new awesome horizons to discuss. But do it separately from here please.
