Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Normal
[quote author="helterbelter"]Rednoise : have fun ! which series do you have ?Snatchman,If you have the manual in full, here's a question you might be able to answer :a few channels are a different version : They have screenlegends, and place for a mic inputtransformer. I noticed the Neutrik NTM4 fits in, but I can't get it to work. Maybe there's another transformer what it's designed for. Also, there's also place for 2 caps to be placed with the transformer, but I don't know which values. My manual doesn't say anything about the inputtransformer, except that it's offered as an option....Does your S series have micinputtrannies ?!?
Snatchman,
Hello helterbelter. No, my " S" doen't have trannies.. Since this board is set up more of a live board ( no tape returns/B input routing), I use outboard pres and come into the line in. I would rather, if I can, get a great sounding line level signal path going! What would you recommend for a direct replacement for the TLO-72 line input amp? BTW.. are those TLO-74s the amps for the EQ?... Thanks.....
[/QUOTE]
