damianschwartz
Hello guys. I'd appreciate if someone can help me out a bit with something. I just bought a Deltalab Effectron 80s delay for very cheap, the only drawback is that the unit is set for 115 volts. I opened it to see if it has some kind of voltage selection and indeed it has it. So i was wondering if the coil would be prepared for double voltage or not, my guess is yes. I included the schematic here, as you can see the voltage is driven by L J K where L and J seem to carry 120v and K 240, on the board there bridges solder for L and J and the one for K is not solder, my guess is by soldering K it'll sum up the 240, so doing that and changing fuse should be right?
