For Sale Demeter HXC optical tube compressor
fluxivity
Virginia, USA
$750. Cool little mono tube compressor; 12AX7 and a Vactrol. The manual says it all: The Hx Series from Demeter Amplification is a revolutionary approach in tube design utilizing innovative tube circuitry for the amplification functions and the latest in solid state for the driver functions. All Hx Series equipment use the finest quality components featuring metal film resistors, high quality film capacitors, and custom toroidal power transformers housed an attractive aluminum and steel single space rack mount case. All units feature fully regulated power supplys supplying 200V to the tubes and + and - 18V for the solid state components, giving all Hx series components tremendous headroom up to + 28 dB output into 600 ohms. More pics below. Here's the spec from the website:
Clean, Classic Compression
Now you can have the sound of a classic tube optical compressor without the noise and low fidelity sound often associated with them. In a compact and versatile package, the HXC-1 HX Series Compressor sets a new standard for sonic quality in tube compressors. The HXC-1 is a mono tube compressor utilizing the revolutionary H tube preamplifier with a classic photo cell compressor section. The unit has a variable attack (.5 to 100 millisecond) and release (100 millisecond to 3 seconds), input sensitivity switch, overload LED, compression control (over 24dB), change and VU meters, side chain outputs, link inputs, low frequency compression sensitivity switch and output gain control.
Specifications
Input impedance:: Balanced 10kohms
Output impedance: Balanced + 28 into 600ohms
THD @ 30dB: gain .050 @ 1k
Response 20Hz to 20kHz: + or - 0.1dB
Gain Variable: 20dB to 30dB
Signal to noise ratio: - 95dB EIN
Tubes: 12AX7a selected
Outputs: XLR, TRS 1/4"
Inputs: XLR, TRS 1/4"
Operating voltage: 230/115V AC
Did my best to get pics of any/all scratches:
