buildafriend
abbey road d enfer said:In addition to what's been already said, what transistors are you going to use that handle 300V Vceo?
This is my main consideration at the moment. What MOSFETS? Initially, all I would like to do is make a working output section with two transistors for up and two for down that I can use a similar design principle to to make into a larger amp. I'd like to worry about all of the transient suppression and brownout after I have a very basic building block. The class D amps use high speed MOSFET drivers which are a further consideration. I'm looking for simple to start and then I'd like to build out from there. Perhaps it's time for a HV bench supply and 2 very high wattage heat sunk 4ohm resistors to run in series or parallel as a load for test. From what i'm reading 2 ohm stable amps are tough to build since you're practically shorting them out with such low resistance.
To answer Ian - a lot of power is needed to move the air in such ways at a night club. It's obviously insane but it's experiential feeling that. The lower your LF cutoff is the easier it is to unload the amp allow it to spit it's self out. The loading of the cabinet on the cone is important in horn loaded bandpass cabinets. I know studio electronics work much better than this but I enjoy a good kick here and there.
Sticking to the amp thing here. Thanks so far to everyone who has chimed in So selecting some transistors...
