Anybody familiar with the Michael Suesserman patent? 1994. Who bootstrapped what, when, has been covered here in years past, so i’m not trying to retread that. Whitlock clearly nailed it in terms of wide acceptance. Suesserman’s approach is focused on non-audio industries - his examples use very large values and require FETs or all-in-one instrumentation amps that aren’t designed for unity.
What I’m curious about are the advantages or disadvantages of this circuit vs. Bill’s circuit, in our world. Both require two well-matched resistor pairs for bootstrap biz; Suesserman’s could more easily be four equal value resistors, and high ones at that. C1-C4 and R1-R4 are described as equal value, but one might scale them so that the cutoff of C1 into R1 and C3 into R2 remains the same (like 1 or 2Hz), with their differential complements doing the same. The main advantage is one less op amp, and it seems more applicable to large gains….mic amps being the obvious AC-coupled application. I’ve tried to work out servos for bootstrapped inputs and haven’t ever found one that sticks (since any value in parallel with the bias resistors negates the bootstrap), but this feels slightly more servo-able, somehow.
I came across it while thinking about buffered -6dB line inputs and front end capacitor/ bias resistor values. It’s pretty easy to visualize either topology without R5-R7 and Rf/Rf/Rg, respectively.
And of course, if @MisterCMRR cares to drop some knowledge, i’m all ears.
