needs stereo drum samples to be really dirtied up, and i'm looking for a solution.
Anybody think that this would give enough DC to dirty things up?
I'd recommend the amplifier section from the pultech clone -
just leave out the eq section for now, and you have a ~20dB
gain tube driver stage with really nice sonic sideeffects.
http://www.gyraf.dk/gyraf2/gy_pd/pultec/pultec.htm
But if you're looking for the sound of these modern
"starved-plate" designs that ate widespread in consumer "pro"
audio, you're better off with distorting by two germanium
diodes..
Jakob Erland
Gyraf Audio
Hey all,
not a tube saturator project, but I had an idea of a
transformer saturator inside my mastering console I will build
in the near future. The input stage would have a rotary switch
where 1 is bypass and the others different gains feeding a
transformer, after which the gain is set back to normal. I
think it could be handy and sometimes could be nearly the only
thing that is needed. The knob could be labelled as "bad-good"
or "less-more".
Does anyone have any idea of the sound of different
transformers - does a Sowter distort more generally than a
Lundahl, for example?
Jaakko
I've kind of had the same idea but I thought it would be a
good experiment to use multiple transformers. From cheap to
expensive for differing charecteristics.
Paul Gold
Digi-Rom
www.vinylmastering.net
Hi Paul,
multiple transformers sounds very good to me. And idea I had
was also to put a passive eq behind the transformer - for
example boosting at lows some amount before and then cutting
it back after the transformer to have different
characteristics.
I quess I'll do this around the preamp of the console: thereby
it'd have options of:
1) totally bypassing the whole mess
2) adjusting the gain without feeding transformer
3) adjusting gain feeding transformer
4) saturating through TFX - lowering the gain back to normal
after it.
Jaakko
I´m working on a simple "variable DC current" Xformer output
stage, remembering most of the lovely "soundmakers" like 1176
rev. D, neve 1073 or telefunken V72 have all DC biased output
transformers or inductors (V72) that make most of the sound.
making the DC current adjustable would give the option for
more or less iron sound on any trannie you choose.
steff
steff
There are some circuits in the thread below that look related. Haven't put a soldering iron to it, but think of using the Fabio '283 output boards for this.so we apply the current to just one side of the windings ?
Gus said:Read chapter 5 of the big red book...
